As per my last post on my thread vcds 00561
I just plugged the car in and it’s showing no faults car started fine and run 30 mins without cutting out iv checked the maf connection replaced the fuel pump relay also fpr all ok the only thing i found is no 2 coil pack is a very loose fitting no 3 is a little loose where the others are tight would this cause the car to cut out?
