Autocheck on, ok.
Fuses checked
Ecu clicks as it should
Fuel pumps been replaced with a 044 motorsport jobby and works fine
No fault codes on the vag com?
try the ignition switch.....the plastic electrical part in the igntion switch
it cracks makes doggy contacts...................
remove dash cluster
remove big plug at reat of ignition switch
small flat bladed screw driver remove 2 small grub scews...might be under paint
care fully remove switch...............old one is white....newer type black
being a 3B, I was going to ask if there was an aftermarket alarm / immobiliser fitted, if it has, it sounds like that might be the problem, starting circuit / fuel pump being the usual 2 circuits...
This is such a bodge, the pictures just dont show how shocking it is
Where to start
Into the back of the ignition barrel is three scruffy tapped wires.
Over the very back through the looms etc is two red wires tapped into a connection that seems to be up right
But one of the ones that comes back is not connected to any thing
This system seems to work as you turn the car off at over 90degs the engine will run and when you shut the door it will stop (pretty **** if you ask me)
Yeah its a butchers Job with out a doubt
Theres a cable that was to short so they put a conection in to make it longer
Need a new switch i think though, as the ignition stays on with out the key in
Mine was like that when I first looked behind the dash, all started when I lost my keys with the immob chip on them out of my rucksack when out on the bike . I removed several kilos of wiring from many alarms and immobilisers, found a spare key under the ashtray though .. Alarms I hate em.
