Faliure to start
  • terrybullwon
    • Mar 2006
    • 8782
    Faliure to start
    Really dont know whats got into my car of late.
    Turn the key nothing happens,
    Autocheck on, ok.
    Fuses checked
    Ecu clicks as it should
    Fuel pumps been replaced with a 044 motorsport jobby and works fine
    No fault codes on the vag com?
    Where do i go next?
    It work fine just 3 hours before
    Cheers James
    Chef
  • DJones
    • Jun 2005
    • 2020
    Sounds a bit like a starter solenoid problem... try tapping it while someone turns the key.
    • terrybullwon
      • Mar 2006
      • 8782
      update,
      you can turn the ignition off and take the key out and the lights and auto check will stay on
      Thanks DJones i will give that ago
      Chef
      • topsparky
        • Oct 2005
        • 2014
        sounds like the ignition switch to me
        1. SHORT SHIFT KIT
        2. PORSCHE CAYENNE CALIPERS
        3. H & R SPRINGS
        4. BILSTEIN SHOXS
        5. NEW BUSHES AND HP2 STRUTS
        8. fmic fitted
        • john881000
          • May 2004
          • 598
          hi James
          try the ignition switch.....the plastic electrical part in the igntion switch
          it cracks makes doggy contacts...................
          remove dash cluster
          remove big plug at reat of ignition switch
          small flat bladed screw driver remove 2 small grub scews...might be under paint
          care fully remove switch...............old one is white....newer type black
          cheers
          john
          there are two types avaible
          • terrybullwon
            • Mar 2006
            • 8782
            this has some thing to do with this bloody after market thing some **** put in theres a wire that dosent go any where
            I will take some pictures
            Chef
            • LHD_Kid
              • May 2006
              • 3696
              being a 3B, I was going to ask if there was an aftermarket alarm / immobiliser fitted, if it has, it sounds like that might be the problem, starting circuit / fuel pump being the usual 2 circuits...
              • terrybullwon
                • Mar 2006
                • 8782
                This is such a bodge, the pictures just dont show how shocking it is
                Where to start
                Into the back of the ignition barrel is three scruffy tapped wires.
                Over the very back through the looms etc is two red wires tapped into a connection that seems to be up right
                But one of the ones that comes back is not connected to any thing
                This system seems to work as you turn the car off at over 90degs the engine will run and when you shut the door it will stop (pretty **** if you ask me)
                Chef
                • terrybullwon
                  • Mar 2006
                  • 8782
                  more pictures
                  any one know if this should be connected?
                  And the two brown wires from the ignition block
                  Chef
                  • 4WheelDrifter
                    • Oct 2004
                    • 5773
                    • Country: Devon
                    I can see a problem in the second picture, a scotchlok.
                    It looks like you have some tidying up to do James.
                    SS
                    • terrybullwon
                      • Mar 2006
                      • 8782
                      Yeah its a butchers Job with out a doubt
                      Theres a cable that was to short so they put a conection in to make it longer
                      Need a new switch i think though, as the ignition stays on with out the key in
                      Chef
                        Mine was like that when I first looked behind the dash, all started when I lost my keys with the immob chip on them out of my rucksack when out on the bike . I removed several kilos of wiring from many alarms and immobilisers, found a spare key under the ashtray though .. Alarms I hate em.
                        Removed in one session...
                          Get yourself a new switch, its a common failure, some say they fail sooner if you have a heavy bunch of keys hanging off the lock..
                          • terrybullwon
                            • Mar 2006
                            • 8782
                            Looks like enough wires and boxes to alarm a nucular submarine
                            I will give a new switch ago, can any one check that this is the right part number?
                            4A0 905 849
                            Chef
                            • Nuvo
                              • Nov 2003
                              • 3825
                              Hi, I just wanted to ask what is wrong with the use of scotlok connectors? Aren't these reliable for making taps/splices or...?
