95.5 crank i 220mm engine
  • mllen89
    • Apr 2015
    • 63
    Hi
    Any one here have build stock engine with a diesel 95,5 crank?, i consider that with custom pistons an rods.
    Known as a Ghetto Stroker I believe.
    Try a search.
    You have to grind a little out of the block to get clearance.
    • mushasho!
      • Apr 2007
      • 163
      And keep rpm limit below 7500rpm max if rod length is 144mm.
      _Rubí_
      • mac2226
        • Jun 2008
        • 1289
        what your going to spend on forge internals you may as well go stroker. This is what I ended up doing.
        • A80Avant
          • Sep 2005
          • 10873
          • Country: Greece
          I have one ready to go in within the next month after long delays. Planning to se the rev Limiter on 7k
          Sent from my SM-N975F using Tapatalk
          • mushasho!
            • Apr 2007
            • 163
            I have that setup... It works well...
            Just need to find a good turbo that likes to stop partying at around 7500.
            _Rubí_
