Engine Rebuild
  • Engine Rebuild
    As per title anyone recommend someone that can rebuild my engine would prefer someone that knows our engines and can source correct parts and known to the forum don't want a cowboy doing the work ! tried around where i'm from and didn't trust the feedback i had why the car is smoking like it is when idleing and smelling oiley. I have had all the gaskets changed as i was told it was oil valve stem seals so changed them all. I don't mind traveling any feedback welcome.
    Have you done a compression test? That will indicate if it needs doing.
    Turbo is the other possible cause.
    Nothelle S2 Avant in restoration
    Wr Ur Quattro (also in restoration)
      error404 should be able to help
        I will do compression test hopefully all ok.
          Didn’t know Alex rebuilt engines?
            You can also try https://www.churchroadgarage.com/ as I rebuilt mine there 2 or 3 times over the years.
              I have done a few
