Engine Rebuild
  • bilko0795
    • Feb 2011
    • 1883
    Engine Rebuild
    As per title anyone recommend someone that can rebuild my engine would prefer someone that knows our engines and can source correct parts and known to the forum don't want a cowboy doing the work ! tried around where i'm from and didn't trust the feedback i had why the car is smoking like it is when idleing and smelling oiley. I have had all the gaskets changed as i was told it was oil valve stem seals so changed them all. I don't mind traveling any feedback welcome.
    • Dec 2017
    • 5984
    Have you done a compression test? That will indicate if it needs doing.
    Turbo is the other possible cause.
    • tango123
      • May 2017
      • 892
      error404 should be able to help
      • bilko0795
        • Feb 2011
        • 1883
        I will do compression test hopefully all ok.
        • bilko0795
          • Feb 2011
          • 1883
          Didn’t know Alex rebuilt engines?
            You can also try https://www.churchroadgarage.com/ as I rebuilt mine there 2 or 3 times over the years.
              I have done a few
