No oilpressure at start
  • S2_avant 19930325
    • Mar 2019
    • 648
    I started the car , oilpressure came right away
      • Dec 2017
      • 5984
      • rustybullethole
        • Aug 2013
        • 531
        How did you fix it, what was the problem?
        • S2_avant 19930325
          • Mar 2019
          • 648
          I tried to start on the starter and without sparkplugs ,, for 20 sec burst 4 times .. then the starter was smoking hot ,, then i start the eninge and the oil pressure came directly ,, som my advice to peolple ,, dont be afraid to start on the key ,, the day before i took away the spark plugs and sprayed a oil spray in cylinders and turn over the manualy. And assebly lube on the cams. I would not run the engine more then 6-7 sec if you dont have oil pressure by then.
          That is just my opinion
          • S2_avant 19930325
            • Mar 2019
            • 648
            The feeling was the engine needed higher revs to build pressure.
            • s0_big
              • Dec 2009
              • 685
              When i was "priming" my two, totally rebuilt engines i got oil pressure without starting the car after running the starter for about 30sec (without spark plugs/fuel).
              When i assembled my engines (to help with the oil pressure build up) i lubed up the gears in the oil pump with "assembly lube" and top up the oil filter with oil. Of course assembly lube on all the necessary parts also.
              Maybe the oil pump wasn't lubed/filled so it had to get some more revvs to suck up the oil from the pan?.. My opinion is that it is much safer to get some oil pressure before you put load on the bearings. Good luck with the car
              • JuizeR
                • Jan 2010
                • 28
                I got a tip from a friend of mine, who works as a mechanic in Toyota dealership, to overfill the engine with oil so that the oilpump is drenched in oil before the first start up.
                1. Overfill the engine with oil, so that the oil level is well above the oilpump
                2. Crank the engine without spark or fuel, so it won't start, and see oil pressure
                3. Once oil pressure is there, drain exccessive oil out and go for a proper start
                This is how I (finally) got oilpressure relatively easy and I think is safe for freshly built engine.
                • Tom_
                  • Oct 2007
                  • 1301
                  • Country: Czech Republic
                  #38
                  Is it a good option to use a starter for a priming purpose? The engine is completely rebuilt on the engine stand. I want to be sure that the oil pump will make some oil pressure before I put the engine in the car and see if there isn't any leak.
                  Audi Coupe Quattro 2.3 20V
                  • SteveH
                    • 4460
                    You can back fill the oil pump by removing the oil pressure sender and then syringe some oil into the hole in the block. This will run down the gallery into the pump and give you oil pressure pretty quickly on the starter motor.
                    91 Modded 3B
                    14 A6 Avant Black Edition
                    • SteveH
                      • 4460
                      Oh, don't forget to put the sender back in before cranking the engine
                      91 Modded 3B
                      • Tom_
                        • Oct 2007
                        • 1301
                        #41
                        I was thinking of pressurize/prime the system with thé oil through turbo inlet/outlet hose
                        Odesláno z mého ASUS_X00QD pomocí Tapatalk
                        • Tom_
                          • Oct 2007
                          • 1301
                          #42
                          I removed and modify an old oil pump sender, welded stainless steel fitting And IT working like charm.. the problém is how to remove IT without spitting thé oil . IT Will be challenge.
