Aux rad delete - bung sizes?
  • Aux rad delete - bung sizes?
    Afternoon all, I've searched and not found this info - apologies in advance if I missed it somewhere...
    What bung size(s) are needed to stop up the pipes when deleting the aux rad?
    I ordered a replacement from GSF (with one of their discount codes, so expensive but not "list price" at £350), but they've just been in touch to say they can't get it. Since mine is leaking, if I can't replace it then it'll have to go.
    Thanks in advance
    Shocked, exhausted, hosed, bushed, dumped, chipped, mounted, filtered, gauged, packed, intermittantly wiped and braked. I mean broken. Now, about the car...
    List price £350???? What on earth??!!
    If your matrix has failed but the end tanks are still good - Get your old one re cored for heavens sake, you will pay around £100.
    GSF should be ashamed.
      They seem to have near permanent discount codes, and the one I used was for 50% off so it ended up being c. £175. I wouldn't have even contemplated more than £200!
      Mine is indeed leaking in the middle so could be re-cored, but I'm also contemplating using the space where the aux rad is for the larger oil cooler mod - hence needing to know bung sizes.
        25mm barbed metal plug from plumbing supply store and hose clamps. 2 of each. Copper plugs would be better
          Thank you!
          Any reason for copper in particular? I can find machined aluminium/alloy pipe plugs in that size easily, but haven't found any copper ones yet.
            You can still get the Aux delete hose from Audi Tradition for a reasonable price. Just fitted mine today and makes it much more tidy
              Excellent! Can you give me a part number or direct link to the part please?
                I used 22mm external stop ends. Any diy store has them.
                1992 80 quattro 20vT
                  https://shops.audi.com/en_GB/web/tra...-893121055b-10
                  Order it now as the shop is closing for update tomorrow.
                    Merlin Motorsport do the bung in aluminium
                      Originally posted by curlyks2 View Post
                      Thank you!
                      I use the anodised aluminium ones from eBay, usually listed as dump valve plug
                      For example
                      https://www.ebay.co.uk/itm/222161705536
                        I was thinking about this last week and have 2 questions: -
                        1. How does the Audi delete hose fit as I thought the idea was that you should not bridge the aux pipes to form a loop but better to bung them as per the above posts?
                        2. If going the bung route, I was also looking at alloy eBay jobs and they offer a range of sizes so is 25mm or 22mm more suitable?
                        Cheers n beers (emoji here)
                        Si
                        Subtle mods here and there
                        2011 A5 3.0 TDi - Lava Grey
                          2. I going the bung route, I was also looking at ally eBay jobs and they offer a range of sizes so is 25mm or 22mm more suitable?
                          Si
                          It's just the hose from the 7a engine which never had an aux rad. It's a perfect fit
                            For reference, 7A has auxiliary radiator.
                            • #15
                              Si
                              The 22mm is reference to the copper pipe outside diametre, add on the thickness of the copper end cap itself and it becomes 25mm. The raised solder ring does am alright job of acting like a bead for clamping your hose clip at.
