Aux rad delete - bung sizes?
  • #16
    Originally posted by John. View Post
    For reference, 7A has auxiliary radiator.
    So the one without the Aux. I thought it was the 7a. Anyone?
    Nothelle S2 Avant in restoration
    Wr Ur Quattro (also in restoration)
    • #17
      Originally posted by HPmuirt View Post
      2. If going the bung route, I was also looking at alloy eBay jobs and they offer a range of sizes so is 25mm or 22mm more suitable?
      I did a bit more digging, and based on the info described here (and attached pic) it looks like 24mm, so I've ordered a couple of 24mm bungs/plugs. As Steve says above a 22mm solder ring cap - after copper and raised ring - will be about right and from Audicted 25mm works fine too.
      I'm a bit rusty with the family album these days, but I think KV, NG and/or NM.
      Shocked, exhausted, hosed, bushed, dumped, chipped, mounted, filtered, gauged, packed, intermittantly wiped and braked. I mean broken. Now, about the car...
      • #18
        NM is like 7A aux rad present!
        • #19
          According to 7Zap, NG engine without air con or tow bar didn't have the Aux rad
          • #20
            Dave my 2-3 NG 10valve aka The kennel has a Auxiliary rad. That's on a G, although I had a 2-3 NG 10valve on H and that one didn't have a Aux rad. No air con on either car.
            • #21
              Hi Lynn, how are you keepng?
              Interesting. Lucky for us Audi still have the hose and it isn't silly money.
              • #22
                I am well thanks Dave,, its everybody else. So I'm told. We know your good as the cars are coming along well. I believe roose motorsport also sell the hoses but don't know price off them..
                • #23
                  Roose coolant hoses (two hoses) for ABY aux rad delete are £130 (at time of writing, NCTS etc).
                  Dave, when you've used that one hose from Audi Tradition to bypass one connection to the aux rad, what have you done to lose/delete the other connection? Short pipe and bung straight onto the radiator?
                  • #24
                    Yes, short length of silicone hose and a bung. I would post a pic but I've reached my monthly limit on tapatalk.
                    • #25
                      Thanks Dave. Picture not needed - I can imagine what it looks like
                      • #26
                        Yep 7a hose is a perfect fit
                        1992 3b S2 Coupe
                        • #27
                          Like this.
