Aux rad delete - bung sizes?
    • Dec 2017
    • 5983
    Originally posted by John.
    For reference, 7A has auxiliary radiator.
    So the one without the Aux. I thought it was the 7a. Anyone?
    • curlyks2
      • 1069
      Originally posted by HPmuirt
      2. If going the bung route, I was also looking at alloy eBay jobs and they offer a range of sizes so is 25mm or 22mm more suitable?
      I did a bit more digging, and based on the info described here (and attached pic) it looks like 24mm, so I've ordered a couple of 24mm bungs/plugs. As Steve says above a 22mm solder ring cap - after copper and raised ring - will be about right and from Audicted 25mm works fine too.
      I'm a bit rusty with the family album these days, but I think KV, NG and/or NM.
      Shocked, exhausted, hosed, bushed, dumped, chipped, mounted, filtered, gauged, packed, intermittantly wiped and braked. I mean broken. Now, about the car...
      • psiconauta911
        • Oct 2007
        • 613
        • Country: Portugal
        NM is like 7A aux rad present!
          • Dec 2017
          • 5983
          According to 7Zap, NG engine without air con or tow bar didn't have the Aux rad
          • LSG
            • May 2010
            • 897
            Dave my 2-3 NG 10valve aka The kennel has a Auxiliary rad. That's on a G, although I had a 2-3 NG 10valve on H and that one didn't have a Aux rad. No air con on either car.
              • Dec 2017
              • 5983
              Hi Lynn, how are you keepng?
              Interesting. Lucky for us Audi still have the hose and it isn't silly money.
              • LSG
                • May 2010
                • 897
                I am well thanks Dave,, its everybody else. So I'm told. We know your good as the cars are coming along well. I believe roose motorsport also sell the hoses but don't know price off them..
                • curlyks2
                  • 1069
                  Roose coolant hoses (two hoses) for ABY aux rad delete are £130 (at time of writing, NCTS etc).
                  Dave, when you've used that one hose from Audi Tradition to bypass one connection to the aux rad, what have you done to lose/delete the other connection? Short pipe and bung straight onto the radiator?
                    • Dec 2017
                    • 5983
                    Yes, short length of silicone hose and a bung. I would post a pic but I've reached my monthly limit on tapatalk.
                    • curlyks2
                      • 1069
                      Thanks Dave. Picture not needed - I can imagine what it looks like
                      • s2driveruk
                        • 12696
                        Yep 7a hose is a perfect fit
                        1992 3b S2 Coupe
                          • Dec 2017
                          • 5983
                          Like this.
                          • curlyks2
                            • 1069
                            Brief update: aux rad removed. 7A bottom hose perfect, and a 25mm Samco blanking cap (as pictured) on the main rad spur. Temps fine.
                            This gallery has 1 photos.
