Aux rad delete - bung sizes?
Urs6 plus project gone -
I did a bit more digging, and based on the info described here (and attached pic) it looks like 24mm, so I've ordered a couple of 24mm bungs/plugs. As Steve says above a 22mm solder ring cap - after copper and raised ring - will be about right and from Audicted 25mm works fine too.
I'm a bit rusty with the family album these days, but I think KV, NG and/or NM.
Capture.JPGShocked, exhausted, hosed, bushed, dumped, chipped, mounted, filtered, gauged, packed, intermittantly wiped and braked. I mean broken. Now, about the car...Comment
According to 7Zap, NG engine without air con or tow bar didn't have the Aux radNothelle S2 Avant
Urs6 plus project goneComment
Hi Lynn, how are you keepng?
Interesting.
Lucky for us Audi still have the hose and it isn't silly money.
Roose coolant hoses (two hoses) for ABY aux rad delete are £130 (at time of writing, NCTS etc).
Dave, when you've used that one hose from Audi Tradition to bypass one connection to the aux rad, what have you done to lose/delete the other connection? Short pipe and bung straight onto the radiator?Shocked, exhausted, hosed, bushed, dumped, chipped, mounted, filtered, gauged, packed, intermittantly wiped and braked. I mean broken. Now, about the car...Comment
Yes, short length of silicone hose and a bung. I would post a pic but I've reached my monthly limit on tapatalk.Roose coolant hoses (two hoses) for ABY aux rad delete are £130 (at time of writing, NCTS etc).
Dave, when you've used that one hose from Audi Tradition to bypass one connection to the aux rad, what have you done to lose/delete the other connection? Short pipe and bung straight onto the radiator?Nothelle S2 Avant
Like this.
Sent from my iPhone using TapatalkNothelle S2 Avant
Brief update: aux rad removed. 7A bottom hose perfect, and a 25mm Samco blanking cap (as pictured) on the main rad spur. Temps fine.You do not have permission to view this gallery.
This gallery has 1 photos.Shocked, exhausted, hosed, bushed, dumped, chipped, mounted, filtered, gauged, packed, intermittantly wiped and braked. I mean broken. Now, about the car...Comment
