Yeah, i have measured resistance aswell, but i see its discussed before on the forum about resistance vs voltage.
As the pdf says:
Across Pins 2 and 3 on the switch: Throttle closed = 750 to 1300 ohms As throttle is opened from closed to WOT = increase to 3600 ohms If NO, replace sensor.
Mine goes to 3100 ohm at WOT, so i guess i would need to replace it?
Bit confused after reading this threat:
https://www.s2forum.com/forum/techni...ps-measurement
Some say measure voltage
As the pdf says:
