Best (strongest/safest) Audi RS2 Toothed Crank Pulley
  • UUUdirs2newcastle
    • Apr 2008
    • 655
    I want to change my Cambelt on my RS2 as I am in the middle of having my alternator refurbished.
    What is the reviews on the Toothed Crank Pulley these days?
    I remember when I was younger, these were an issue for cracking?
    Do I order new Genuine one from Audi Tradition, or a ‘stronger’ new billet ‘bettered’ one like these ?
    https://www.ebay.co.uk/itm/163686549862
    https://www.ebay.co.uk/itm/223945178932
    Please help guys.
    • Dec 2017
    • 5992
    I highly recommend you get one from James on here. It's the same as the first link you have posted but if you send him a PM, I think there is a Forum member discount.
    https://www.s2forum.com/forum/member...e9#post2090593
    • Antsa
      • Nov 2016
      • 613
      As Dave said, billet pulley from James (terrybullwon on here) and you won't have to worry about it again. Use appropriate crank locking tool when undoing the pulley bolt
      • UUUdirs2newcastle
        • Apr 2008
        • 655
        That’s great news! Where is best place for a Crank Locking Tool guys?
        • tango123
          • May 2017
          • 892
          error404 sells a crank locking tool
          • Antsa
            • Nov 2016
            • 613
            Error404 should have them for sale. I purchased my tool directly from the dealers, part vag 3256. I have ABY and the tool bolts straight to the block if you don't have AC in the way. I have AC, but i managed to get away with it with some help from a friend.
              • Dec 2017
              • 5992
              Search changing RS2 camber here before you start. There are a few very important things you need to know, like never use an impact gun and RS2 timing marks are off set and different to S2. Change the water pump, tensioner and crank bolt at the same time and go for quality parts. You will also need to borrow a heavy duty torque wrench capable of 450nm!
                Originally posted by Tractor Dave
                Search changing RS2 cambelt here before you start. There are a few very important things you need to know, like never use an impact gun and RS2 timing marks are off set and different to S2. Change the water pump, tensioner and crank bolt at the same time and go for quality parts. You will also need to borrow a heavy duty torque wrench capable of 450nm!
                Spellchecked for you Dave
                  • Dec 2017
                  • 5992
                  Bl00#y auto write
                  • UUUdirs2newcastle
                    • Apr 2008
                    • 655
                    Thanks Dave, where is the best place to buy a Genuine or good reliable brand like Febi Bilstein Crank Bolt & Water Pump ?
                    • UUUdirs2newcastle
                      • Apr 2008
                      • 655
                      Can I just get the timing marks lined up where they are now, take some photos, make sure I know where they all are and should be, then get some bright paint and a ‘screwdriver end’ and mark it all up? Cams, Flywheel, lower pulley etc?
                      Where can I buy a genuine or OEM quality belt tensioner also?
                      Ive decided to change all the belts and the Alternator too.
                        • Dec 2017
                        • 5992
                        I wouldn't use the febi crank bolt as the collar is very thin. Get a genuine one from Audi Tradition. The SKF water pump and idler bearing are good quality replacements. I would also recommend a new diamond washer if yours looks damaged. Ebay.de for that, 30 euro's.
                        Buy SKF direct on their website. There are a lot of fakes about.
                          • Dec 2017
                          • 5992
                          If you search the Forum the correct timing marks will be here. Ignore the damper mark as it's not very accurate. Go by the mark on the flywheel.
                          I may have said it before but worth repeating, never use an impact gun on either pulley!
                            • Dec 2017
                            • 5992
                            • UUUdirs2newcastle
                              • Apr 2008
                              • 655
                              Thanks Dave, I owe you a few beers! :-)
