RS2 Oil Consumption
  • mak2503
    • 235
    • Home: Scotland Current: United Kingdom
    RS2 Oil Consumption
    My RS2 seems to have a drink problem.
    Is it normal for her to go through 1 litre of oil every two weeks?
    All I do is about 500 miles per week to and from work on mostly motorways travelling about 80mph.
    The car has a slight knocking sound from the top of the engine which I have not heard before so I checked the oil and it is about a millimetre off the bottom so the oil is going somewhere.
  • GlynRS2
    • Dec 2003
    • 307
    I have never really had to top mine up between oil changes which I have done every 5,000 miles. So I would find that quite unusual. What oil are you using?
    Glyn
    Ex-Polar Silver RS2
    Sprint Blue RS4 - new toy :mischeif:
    • mak2503
      • 235
      I have been using Castrol GTX Magnatec plus another Castrol in a gold bottle but I can't remember the name of it.
      • alg
        • Apr 2004
        • 1160
        Mine uses oil. Maybe not as much. What spec oil ? Mine uses 5-40w quicker than 10-40w. It can be normal but check the oil cooler has not begun to leak.
        Is there any evidence of oil from the exhaust (turbo seals) ? black smoke (lots of white normal as water in the exhaust system burns off)? black deposits on rear bumper above exhaust exit.
        Need to check oil pressure &temp sensors in the engine block are not leaking. Finally if you draw a blank consider valve stem & or tappet problems
        Get the car looked at by someone who understands the engine
        Alastair
        RS2
        • blown_vr6
          • Apr 2005
          • 406
          1mm off the bottom of what - the min/max marker or the dipstick??
          Whats your oil pressure like?
          Any visible smoke on deceleration??start up??full boost??
          GTX magnetec is nasty oil - its not even really a semi synthetic as its mineral based - not what id be using in an S2 anyway.
          Pete.
          'If you ain't broke it you ain't trying hard enough'
          Oh sh*t i broke it
          94 S2 Homefried Decatted Slipperwagon,QRS Top Mounts,Ally Subframe bushes,Poly ARB & Wishbone bushes,RS2 ARB's,Koni & H&R's,Cupra Brembo's and 312mm discs
            • GlynRS2
              • Dec 2003
              • 307
              You may wish to read the S2 forum definitive oil thread:
              If the car appears otherwise healthy I would try changing the oil to the 10w-50 recomended by Oilman
              Glyn
              Ex-Polar Silver RS2
              • rs2315
                • Jun 2006
                • 867
                Quantum oil Synta Gold.
                GSF about £28
                rs2315.
                • mak2503
                  • 235
                  Thanks Alistair I will check out the oil cooler. There is not any smoke out the back usually just the white smoke on start up.
                  BlownVR6 - I meant 1mm off the bottom of the dipstick. There is no smoke on deceleration or full boost.
                  I know that Magnatec is not the best oil but at £9 for a litre I thought it would be a decent oil to use. The gold bottle I was talking about is Castrol Edge and it is £14 for a litre bottle so it can't be that crap.
                  Also I have been checking the Instruction Manual for the RS2 and it says 'It is normal for the engine to use a certain amount of oil: oil consumption can be up to 1.0 litre per 1000km'.
                  So maybe the 1 litre that I am using is normal.
                  Also why would the car not be telling me that my oil is low. My S2 has a little yellow oil can that came up when the oil was low so the one on my RS2 must be broken.
                  • blown_vr6
                    • Apr 2005
                    • 406
                    Mak - letting it get to 1mm off the bottom of the dipstick when you know it uses oil is criminal imho.
                    You shouldnt rely on electronics to tell you when to add more oil as one day they will let you down at great cost to yourself.
                    Letting the oil get this low is not good for your engine or the oil itself as you make the oil run hotter and work harder when it is low.
                    Best thing you can do is drain the oil, change filter and replace with decent oil, just because magnetec is 7 quid a litre does not mean its not overpriced junk.
                    Also mixing it with a full synthetic like Castrol edge is a waste of money imho - stick to one oil.
                    Pete.
                    Oh sh*t i broke it
                    • Ross
                      • Aug 2005
                      • 3399
                      My Avant is using oil at about the same rate. I found out pretty much the same way, I'd recently checked the oil and it was about 1/2 way, OK I figured - besides my old Coupe didn't use much (about one top-up per 5k, even before the rebuild).
                      A few weeks later, and not many miles either, it developed a tappety sound.. concerned, I checked the oil at next opportunity and was shocked to find it about 1mm BELOW the min line!! About 1l, and it was back to max. I'll be checking it every week from now on...
                      Short of it is, I dont get any smoke and I used to drive my bro's 3-series that used oil at about the same rate. Not a problem, according to BMW...
                      I'm gonna drain it and swap to my 'normal' 10W-50 when I get a chance, will be interesting to see how that lasts.
                      • caterpillar
                        • 2480
                        you may use the wrong oil, but you have to check out the small oilhose, in the cranc vent, at the left side of the engine..is it ok, not swollow inside...or sticky...
                        or: the pistonskuirt are broken or a sidecracked piston; from the underside the oilinjektors to the oilring( 3 ring).... spec at the 3 sylinder..you may rebuild the engine..
                        • alg
                          • Apr 2004
                          • 1160
                          Yes the crankcase breather circuit to scavenge oil. Changed mine with no difference on engine oil use but it was not as fouled as AAH/Angus RS2.
                          Get a true fully synthetic 10-40w such as Motul (my present favourite) and check levels every weekend and/or after a long hard run.
                          Alastair
                          RS2
                          • lune
                            • Jan 2005
                            • 109
                            Mak,
                            I happen to have some proper oil "Silkolene Pro S 10-50", as your a local I can save you going to Halfrauds and sell you one of my spare tub's for less than your £9/litre.
                            You could just buy it online opieoils.co.uk, however if your desperate for a tub send me a PM. (I'll let you take me for a spin in you RS2 )
                            There are only a couple of oils I would use in my car and for me this is one of the best
                            • B300ABT
                              • Feb 2005
                              • 130
                              I don't think my RS2 used more than 0.5 litres of Synta Gold per 1000kms max.
                              As regards choice of oil, the only reason I used Synta Gold was because I used it's semi synthetic brother, Synta Black, in my old urS4, and had no problems whatsoever in 120000 miles of mixed driving.
