Idle valve info
    Best solution is none of these. Use e-throttle
    • S2_avant 19930325
      • Mar 2019
      • 648
      For sure , but price there after.
      The idle pwm works , but for that car its not needed , it will will work with a solenoid. I need it for idle. Feels to much money to soend for idle. The ordinary throttle works fine.
      • SSPRL
        • Aug 2020
        • 18
        • Country: Ukraine
        Alex, I'm sorry, I'm stealing your ideas
        This gallery has 2 photos.
        • S2_avant 19930325
          • Mar 2019
          • 648
          With all necessary parts for it to work , what will the price end up to ?
          • SSPRL
            • Aug 2020
            • 18
            • Country: Ukraine
            #20
            Pedal box 20$
            ibiza sensor 20$
            throttle body 100$
            Aluminium 20$
            Adapters handmade
            if you are talking about it
              I don’t care if it’s for your own use
              Besides, you didn’t make them quite as nice
              • SSPRL
                • Aug 2020
                • 18
                • Country: Ukraine
                #22
                looks very very compact . tell me it's not 68mm TB, otherwise I'll throw my adapter in the trash bin
                • S2_avant 19930325
                  • Mar 2019
                  • 648
                  So if i want to go with the 68 mm throttle body ( how should i think choosing 68mm or 72mm ? ) is it horsepower related ?
                  What else do i need to make it work on my audi s2 avant ? Looked in your webshop.
                  If you use E-throttle you remove the need for IDLE solenoid .. correct ?
                  I use MAXXECU and original pedals.
                    It is 68mm throttle. It is used with silicone adapter to fit S2/RS2, throttle body is not clocked at an angle due to 2pcs adapter plate
                      68mm is just fine, unless you make big changes to your intake also. We did 840hp on E85 with a 2.5 stroker and 68mm throttle so it’s pretty capable. You need to use TDi pedal box or wait a little while, we are working on a bolt-on adapter to use a B6/B7 e-pedal.
                      Yes idle solenoid is no longer used
                      Alex
                      • S2_avant 19930325
                        • Mar 2019
                        • 648
                        Then i will wait. Let me know when it is done. Thanks for the part , water connector on the back of engine block. Great quality. Adonized to.
                          No problem
                          Thanks for your support
                          • S2_avant 19930325
                            • Mar 2019
                            • 648
                            No problem
                            What is the status on the epedal ?
                            "68mm is just fine, unless you make big changes to your intake also. We did 840hp on E85 with a 2.5 stroker and 68mm throttle so it’s pretty capable. You need to use TDi pedal box or wait a little while, we are working on a bolt-on adapter to use a B6/B7 e-pedal.
                            Yes idle solenoid is no longer used"
                            Best Regards
                            • S2_avant 19930325
                              • Mar 2019
                              • 648
                              What is the original inlet size on the throttle body on audi s2 ABY ?
                              Best Regards
                              • Rikki Kitto
                                • Feb 2010
                                • 6276
                                I'll measure mine later for you if no one pipes up
