ID of the oring on steering pump
  • ID of the oring on steering pump
    What exact o-ring fits on the big flat cross bolt ?
    20210716_102000.jpg The other bolt / banjo bolt/on the pipe ,, is there any place to find it without a lot of shipping cost ?
    This gallery has 1 photos.
    Swe: Vilken sorts pump är det? Har du nått nummer på den? Jag har garanterat banjobulten.
    Eng: What typ of pump is it? You have any nr on it? I think i have that banjo bolt.
      Not sure of the o-ring size but I bought one with the plug from the this seller recently. (Not easy to find the plugs with o-rings)
      https://www.ebay.com.au/itm/13354444...0AAOSwkHxb6VQz
        Its not a banjo bolt ,,, its a bolt with a small like 2mm hole on side and filter on the bottom on the bolt
          Filtered banjo bolts exist
            Yes , but i have not found a bolt like the one i have. The side hole on the bolt is only 1-2mm in diameter. I belive that is important so you have correct pressure on the steering.
              Yes it’s definitely a special bolt
                Has anyone successfully ID'd the specs on just the o-ring? 24EUR is steep for the bolt and o-ring, especially because you can usually clean up the bolt seat enough that it won't create problems.
                  I got to 2 original orings from the audi dealer ship.
                  Will check if they have the size.
                  The only 2 left her.
                    17mm ID, 21mm OD, 2mm thick.
