Hello all,
i've recently had my distributor refurbished and while I finally got the engine running it was clear it was running rough and misfiring. Leads where to blame first which I changed, but misfiring continued to happen. The first rotor arm however that was supplied ended up destroyed inside of the dizzy cap (no driving, just idling) after a few runs which also destroyed the pin inside of the dizzy cap.
I got supplied a new rotor arm (they told me they had supplied me with the wrong one the first time) - got second rotor arm and dizzy cap installed, and the car doesn't start anymore (starter motor has been checked and is working).
Read both on the FB page and on the forum that these cars are very particular about the rotor arms, so i'm wondering which one is the correct arm to use for my setup. I'm assuming I need a 7A rotor arm as its a 7a distributor?
Engine is a 91 3B with what appears to be 7A cams (bought car like this)
Distributor p/n is: 034905205J (7A according to etka)
Would be good if someone could help to confirm....otherwise contemplating just ditching this setup and going for coils instead (but prefer to keep the car oem)
Thanks in advance
Thanks in advance
