7a distributor in 3B engine
  • GurjinderSembhi
    • Nov 2019
    • 70
    • Home: Denmark Current: United Kingdom
    Hello all,
    i've recently had my distributor refurbished and while I finally got the engine running it was clear it was running rough and misfiring. Leads where to blame first which I changed, but misfiring continued to happen. The first rotor arm however that was supplied ended up destroyed inside of the dizzy cap (no driving, just idling) after a few runs which also destroyed the pin inside of the dizzy cap.
    I got supplied a new rotor arm (they told me they had supplied me with the wrong one the first time) - got second rotor arm and dizzy cap installed, and the car doesn't start anymore (starter motor has been checked and is working).
    Read both on the FB page and on the forum that these cars are very particular about the rotor arms, so i'm wondering which one is the correct arm to use for my setup. I'm assuming I need a 7A rotor arm as its a 7a distributor?
    Engine is a 91 3B with what appears to be 7A cams (bought car like this)
    Distributor p/n is: 034905205J (7A according to etka)
    Would be good if someone could help to confirm....otherwise contemplating just ditching this setup and going for coils instead (but prefer to keep the car oem)
    Thanks in advance
    Check you distributor static timing
    3B is very sensitive to this.
    • GurjinderSembhi
      • Nov 2019
      • 70
      thanks will check again (not the most inspection friendly place!) - however is the rotor choice anything to worry about? I am not confident with the rotor arm supplied so thinking about getting a 3b specific one (not 7a one)
        You need the 3B rotor with the narrow tip.
        Very important that you don’t use the one with the wide tip.
        • GurjinderSembhi
          • Nov 2019
          • 70
          uhmmm....wrong one for sure then!
          Will get the narrow one. How do I know that something bad has not happened?
            With the wide rotor it’s possible to get spark hop inside the dizzy and bend a rod.
            It’s pretty unusual though!
            Audi 5000 / 200 / V8 Discussion - More Info on Broken 3b - Hey Guys, I was trying to figure out what all parts I need to get for the car and remembered seeing something on sjmautotechnik about the 3b having a unique distributer rotor. When I read the second paragraph my jaw dropped. Ran out to the garage to check and...
            • GurjinderSembhi
              • Nov 2019
              • 70
              hoping nothing major happened then!
              Just cancelled my order from TPS seeing the article from SJM and ordered the correct part from Quattro Corner who was very helpful.
              Thank you very much for your help Newsh - with any luck I can get it ready for AITP
                No worries
                You need to check timing using the window on the bell housing and the marks inside the dizzy, the mark on the front pulley is not accurate.
                Put the car in gear and roll forwards to the Zero mark then check the dizzy (spark plugs out makes it easier)
                It would be a good idea to check the marks on the cam wheels and cam pulley too, just to be sure the valve timing hasn’t slipped. The keyway sun the cambelt sprivkets are prone to breaking.
                • larsaskogstad
                  • May 2020
                  • 674
                  • Country: Norway
                  Correct tip should be 11mm
                  https://www.s2forum.com/forum/member...-3b-1991-coupe
                  • GurjinderSembhi
                    • Nov 2019
                    • 70
                    Got the new rotor today finally. A few screenshots for comparison and the right one on the far right including the Bosch box.
                    waiting for the rain to stop so I can go test it out
