Guys anybody know anything about this manifold? from http://www.irry.com/index-eng.html
Furans reverse intake manifold
It's not found another pic goodness knows who they are though.Attached FilesComment
Email back from Michael:
More of intake is soon on the homepage.
I do with duel and single plenum. it is up to the customer.
Yes the intake manifolds is with idele valve connection.
I we ship worldwide!
best reagards
furan.
Sounds promising http://www.s2forum.com/forum/showthr...?t=3656&page=4
Bit I dont like there is cutting off the tightener on the PAS pump mountI'll try to make a list:
- Drill holes and get fittings for the vacuum hoses. Goes in the metal plate next to the "Furans" sign.
- Longer throttle wire, and a pipe/tube that the wire covering goes into.
- Longer cables for TPS, temp sensor and idle motor.
- Cut off the tightener on the power steering pump mount.
- Dunno if it's the same thing for all - but I removed the rubber stud on the left side of the main rad and replaced it with a ordanary bolt to get the rad closer to the left fender for better clearance between the rad and the IM. Also cut some in the hood isolation for more clearance.
Apart from that it's just "some" plumming from the IC...
:mischeif: Let me know if your going to get one of these Jamo?Furnas: I do with duel and single plenum. it is up to the customer
ChefComment
It's sounds good the only problem is it's plus your original manifold for this product.
I have a powder coated RS2 manifold which no way would I give to be cut up.
I'm waiting to hear from him regarding the dual plenum plus hoping floddy can give some feedback to his work.Comment
I would be interested in a dual, i guessed that might be the case but are there not differences with the 3B, ABY and RS2 inlet sizes?
ChefComment
