20220404_073915.jpg Of course . if there is now washer in the front , mine is 4 mm , then the complete front hub to all the belts will come 4mm closer to engine , i mean it cant travel out. Will check this. This is the washer that was in in there.
20220404_073845.jpgSo the underside of the bolt goes directly to that surface at the bottom , no washer ? The i must pu a bit of oil under the bolt head to when i tourque it.
2022-04-04_074455.jpg Why is there no 5th hole for the "pin" on the hub pulley ? There is one on the belt holder pulley. I start thinking if they have put some other kind of belt pulley on the crank ??
