Stalling issue
  • kwlw
    • Sep 2004
    • 1025
    • Country: Lithuania
    #61
    Originally posted by Corey
    Car has been remapped to allow for the different MAF location and the car doesn't stall anymore, sorry for not updating we have been busy moving this week and our time on the forum has been limited to (very) early mornings and (very) late into the evenings.
    Will you heat shield true MAF anyhow? Or just leave it as it is in the picture? Maybe I'm paranoic, but now I always put finger to check how hot aluminium part of the map is. If it's too hot for finger (60+ C), then it's too hot for chips inside.
    Sau
    • kjetil fykse
      • 5
      • Home: Norway
      #62
      Originally posted by Jon441cc
      Good work Corey, what did you you have to change on the map to convert it ?
      I was wondering the same.
      kjetil
        I seriously doubt that the detailed techincal information would be released to the forum regarding the mapping it is their work after all.
        • Jay
          • Jul 2004
          • 599
          #64
          wow
          Jamo I find your new avatar strangley hipnotic
          Jay
          • Corey
            Banned
            • Sep 2003
            • 2793
            It's that technical even I don't understand it
            Corey
            01636 822288
            • Markarina
              • Mar 2006
              • 511
              • Home: United Kingdom Current: Switzerland
              #66
              okay probably a dumb question, brain finally kicking and remembering back to when I was actually writing engine management software, is their any reason why this problem cannot be fixed by changing the ORFCO map without having to re-site the MAF ?
              • A1QSHIP
                • Aug 2004
                • 975
                Jay
                Like a couple of puppies playing in a pillowcase.
                "Nulla tenaci invia est via"
                • S2_Dave
                  • Aug 2005
                  • 456
                  What's the ORFCO map?
                  David
                  '91 3B S2 Coupe
                  • Mihnea
                    • 1288
                    #69
                    Never heard of an ORFCO map on any Bosch motronic box ever, are you sure this isn't something only used on Ford ECUs? EEC-IV or whatever they are...
                    www.MRCTuning.com
                    info@MRCTuning.com
                    Workshop Directions
                    • Mihnea
                      • 1288
                      #70
                      BTW Corey, I thought the initial stalling issue was long fixed by some miraculous software that you catered for, and that my software was causing it???? Funny eh?
                      www.MRCTuning.com
                      info@MRCTuning.com
                      Workshop Directions
                      • Corey
                        Banned
                        • Sep 2003
                        • 2793
                        Hi, Well the Coupe has had quite the overhaul; spec roughly as follows: Rebuild w/ forged rods, RS2 head-gasket, RS2-EM, RS2-IC 37lb injectors, 4.2bar FPR GT3071-R MRC remapped by Mihnea (996 brakes and uprated suspension of course!) I've updated this thread on the S2 forum, from page 4...
                        You mean this thread? I don't actually think I said anywhere that your software was causing the stalling, merely the car had an issue.
                        Yet again you seem to be determined to drive a wedge between us two, I cannot see your logic but whatever
                        Corey
                        01636 822288
                        • Markarina
                          • Mar 2006
                          • 511
                          #72
                          Would have to admit I'm not an expert on Bosch ECU's so couldn't comment on whether an ORFCO map is present, but I suspect that their must be either an ORFCO or deccel fuel map otherwise we would have flame throwers for exhausts, unfortunately my Bosch blue book is in the office and I am stuck at home for the time being so I can't check up on Bosch's thinking.
                          ORFCO = OverRun Fuel Cut-Off
                          • Mihnea
                            • 1288
                            #73
                            ORFCO in Bosch speak for the S2 is called TLSN or tl schwelle für schubabschalten. Or load threshold for deceleration cut off in simple terms.
                            Corey, I thought I had understood that the software you got on that particular car fixed the stalling issue, nothing more. If I understood it wrong, then great. Nothing more, nothing less.
                            www.MRCTuning.com
                            info@MRCTuning.com
                            Workshop Directions
                            • S2_Dave
                              • Aug 2005
                              • 456
                              Software alone wouldn't fix it - it even had a standard ECU in temporarily as a test. With the MAF moved to the pressure side it hasn't stalled once since. I did blow a hose off the exit side of the MAF last week though. I need to somehow hold the two hoses either side from pulling away from each other. Having said that, the hose hasn't come of again and it's been pushed hard since.
                              David
                              '91 3B S2 Coupe
                              • Corey
                                Banned
                                • Sep 2003
                                • 2793
                                When she is next in Dave we will machine some grooves onto the areas where the hoses sit so it gives a bit of bite.
                                Corey
                                01636 822288
