Anyone know of any mobile / nonmobile decent auto electricians to fix nonstarting s2?
  • K Simmonds
    • Dec 2007
    • 7627
    Glad you found the cause of it not starting.... However I'd want to know what caused that fuse to blow, they don't just fail on their own unless they're extremely old, is 20 amp the correct rating for that location to start with?
    1990 B3 2.0 80 quattro.
    1992 C4 2.8 Avant quattro
    1994 MTM RS2.
    1998 B5 TDI quattro Sport.
    2000 B5 TQS.
      • Dec 2017
      • 5992
      Well done. As Kit says a bit concerning. At least you now know where to look first if it happens again.
      • Chris5044
        • Feb 2005
        • 1663
        Hey thank you everyone! My electrician plumbed this into the circuit for the new coils, emerald ecu and setup.
        I arched the alternator months before and blew the voltage regulator on the rear of the alternator, I think it was slightly linked to that arcing of the terminal incident. (New voltage regulator sourced and installed on alternator) - now new fuse in and will observe. Deffo my thoughts also
        • K Simmonds
          • Dec 2007
          • 7627
          Arcing out the back of the alternator (which is really quite easy to do, hence disconnecting the battery before working on it) could well have caused it to pop...
          However then I'd of expected it fail straight away, not sometime in future, all you can do is keep an eye on things... Are you sure 20A is the right rating for that fuse?
          Hope your car doesn't let you down over the weekend, have spare fuses on hand!
          1994 MTM RS2.
          2000 B5 TQS.
            Yeah carry spare fuses.
