Alternator - what choice to make
  • K Simmonds
    • Dec 2007
    • 7627
    Also check the larger oil switch/sender is the correct type. There's one with 0.3 bar switch and one with a 1.8 bar switch, yours should be the 0.3 bar type.
    1990 B3 2.0 80 quattro.
    1992 C4 2.8 Avant quattro
    1994 MTM RS2.
    1998 B5 TDI quattro Sport.
    2000 B5 TQS.
    • S2_avant 19930325
      • Mar 2019
      • 648
      will check
      • Bowie69
        • Nov 2013
        • 2675
        I didn't think the temp sender went to the auto check....?
        Anyway, there's a load connections under the dashboard which I found to be corroded a little, had bugged me for years but always solved itself once the car dried out in summer.
        I finally solved it when I found those corroded connectors and gave them a good scrape and contact cleaner.
        • Bowie69
          • Nov 2013
          • 2675
          Here you go, long post, relevant bit further down:
          • K Simmonds
            • Dec 2007
            • 7627
            You know what, I think your right there Peter... If the wire for the temp gauge isn't connected the gauge reads flat out but I'm not 100% sure it's linked to the Autocheck.
            1994 MTM RS2.
            2000 B5 TQS.
            • S2_avant 19930325
              • Mar 2019
              • 648
              Ok ,, but did you have the same issue as me and they were corroded and it fixed the oil light ?
              • Bowie69
                • Nov 2013
                • 2675
                Yes, exactly that.
                Essentially I had to trace the wiring all the way from sensor to dash binnacle to find it -read my post, it is all in there.
                • S2_avant 19930325
                  • Mar 2019
                  • 648
                  Yes, exactly that.
                  Great im in the garage ,, will check it right now
                  • S2_avant 19930325
                    • Mar 2019
                    • 648
                    Hmm my panel under the dash does not like on the picture
                    • S2_avant 19930325
                      • Mar 2019
                      • 648
                      Looks like this
                      This gallery has 2 photos.
                      • K Simmonds
                        • Dec 2007
                        • 7627
                        One's a 7A and ones an S2, hence the differences, though I think Peter's suggestion is still along the correct line of thinking. Check any ground points you can find and the wires going to them as well any other connections under there that lead to the clocks.
                        I bet it's something really simple, just a case of finding it.
                        1994 MTM RS2.
                        2000 B5 TQS.
                        • Bowie69
                          • Nov 2013
                          • 2675
                          Trace the wire colours...
                          • S2_avant 19930325
                            • Mar 2019
                            • 648
                            How do you mean ?? Lead to the clocks ? ... i have already all the ground cables under the dash harness,, a lot of grounds. So its probably somekind of ground or cable issue of some sort ? The cables that goes from the fat oil sender those cables is that i should correct ? As i have searched a lot .. that is the sensor that makes the lamp flash .. hmm if take it out i can test it manually ... plug the hole int the block .. and put air pressure on the sensor , i have rig for it. Thats how i tested they worked before installing them. Hmm
                            • Bowie69
                              • Nov 2013
                              • 2675
                              You need to find the wires under the dash, and trace the signal, it may not look like mine but it will be similar.
                              There are wiring diagrams out there if you search.
                              • K Simmonds
                                • Dec 2007
                                • 7627
                                Leads to the clocks= wiring to the clocks, specifically the Autocheck.
                                As Peter says above you really need to find the wires from the pressure switches to the Autocheck and test them for continuity, one could be broken or earthing out on the body.
                                I can imagine it being really frustrating to find this problem but I expect once you find the solution it will be obvious.
                                1994 MTM RS2.
                                2000 B5 TQS.
