Maximum power K24 7000
  • K Simmonds
    • Dec 2007
    • 7627
    Originally posted by vidar skotheim
    Mine to have larger high flow ex wheel . New design compwheel . And even make new insert into comphousing .
    not much more to do with these now !!!
    Wow, that new K24 looks like a work of art! You've obvious put a lot of work into cramming those wheels into what looks like a stock K24 from the outside, what sort of power/torque is that unit capable of?
    1990 B3 2.0 80 quattro.
    1992 C4 2.8 Avant quattro
    1994 MTM RS2.
    1998 B5 TDI quattro Sport.
    2000 B5 TQS.
    • vidar skotheim
      • Apr 2005
      • 566
      • Country: Norway
      #32
      380++ real hp ..
      depends engine setup
      • K Simmonds
        • Dec 2007
        • 7627
        380++ real hp ..
        That's really very impressive, opening up the turbine housing to take a 50mm exducer turbine/shaft which itself is considerably more modern in design than the old Porsche 944 or K24 7400 shaft is a really game changer.
        Along with fitting what looks like as big a compressor wheel as possible that makes a very attractive package, especially for people who have to worry about parts being original in appearance.
        1994 MTM RS2.
        2000 B5 TQS.
        • vidar skotheim
          • Apr 2005
          • 566
          • Country: Norway
          #34
          Yes sold many of these . And seem most are very happy with spool and power
          • K Simmonds
            • Dec 2007
            • 7627
            Well it produces RS2+ spec power in a simple K24 7000 package which is awesome work..
            I guess it depends a little on the spec of the engine, capacity, head work etc but in general on say a stock S2 engine when does it start to produce boost?
            It's probably pretty dam good on a 10VT as well.
            1994 MTM RS2.
            2000 B5 TQS.
            • Chris M
              • Sep 2003
              • 1030
              My S2 achieved just over 300 with a modded K24 I built, slight cutback turbine and custom stock size billet wheel.
              As people have said RS2 turbo is the best combo for response, power and torque.
              Cheers,
              Chris
              Silver S2 Avant : Sold
              • Chris M
                • Sep 2003
                • 1030
                Cheers,
                Chris
                • vag_noob
                  • Nov 2010
                  • 72
                  • Country: New Zealand
                  #38
                  Are chips available for k24 7000 URS4 upgrade on stock engine? What injectors are required, RS2 replica?
                  edit: forgot to say auto trans...
                  • vidar skotheim
                    • Apr 2005
                    • 566
                    • Country: Norway
                    #39
                    Not for auto trans
