Update: I have again removed the IM to access the distributor cap and rotor arm. I noted the rotor arm was supplied incorrectly and as no Bosch item can be found, I have cut down the 17.9mm rotor arm to 11.8mm. Refitted everything ensuring the rear dist cap clip was fully secure this time (was so stiff it gave a false impression it was snapped down when it wasnt). All reconnected and still no start despite all injectors working and spark at the spark plugs. I have not touched any of the timing or distributor.
However I did note this time when fitting the new cap, the metal strip in the clip slot is on the opposite side to the original (see photo). I assume this is an earthing strip or ??? It's just that on the original it would sit right next to the Hall sensor connector...any idea what this strip is?
