3b timing belt tensioner in place of roller on oil pump
  • booested4door
    • Feb 2015
    • 120
    Hey all!! I have a 2 bennett serpentine setup on my b2 20vt. this setup uses an AAN waterpump..so adjustment, a 3b belt and no tensioner at all. Ironically the 3b belt is perfect tension. THat said, Id like to add a vw 8v tensioner in place of the oe roller on the pump. what are peoples thoughts here? any issues with drilling the block for the larger bolt? I know this is how the stroer guys get the tensioner integrated, but thats a different block.
  • varia
    • 821
    • Current: United States
    "this setup uses an AAN waterpump..so adjustment, a 3b belt and no tensioner at all." What?
    • booested4door
      • Feb 2015
      • 120
      yup..... 2bennett.....ness. hence why i want to add one.......
      • AndyP
        • 6049
        The 3B uses the waterpump as the tensioner, it has slots instead of holes. I saw a picture the other day where they were using a relay roller off another Audi that looked the same as the 3B one but had an eccentric adjuster in the middle, I think it was from the 2.0 16v ACE engine.
        • booested4door
          • Feb 2015
          • 120
          i saw that too! thats what im trying to accomplish, but on a 3b block
          • AndyP
            • 6049
            I've ordered one, I have a stroker block but a 3B oil pump, I'll report back when I've trial fitted it.
            • sal_s2
              • 1287
              Good idea
