1996 RS2 No spark
    Originally posted by bazgreener
    Good info, thanks :-)
    I have a buddy who may be able to fix your Motronic ECU, he knows the common failure modes and has done a few for me and others. I need him to look at my RS2 spec ECU as it went wrong while on loan recently (otherwise I'd be happy to lend it to you)
    PM me if you want me to enquire about fixing yours.
    • andyg plym
      • Nov 2006
      • 4646
      I had an old aby ecu repaired in ivybridge if you want the details. He’s an expert and does all main dealer work too
      • bazgreener
        • Jan 2025
        • 27
        I may take you up on that offer. I have ordered the Maxxecu now anyway as it's a better option for future tuning.
        • bazgreener
          • Jan 2025
          • 27
          Is that Tamar Electronics? I have used them in the past and didn't have much luck.
          • andyg plym
            • Nov 2006
            • 4646
            Yes it was tamar electronics, that’s a shame. Are you still aiming to get the car started to see if the car is still salvageable?
            • bazgreener
              • Jan 2025
              • 27
              I should have the Maxxecu next week so should get it running and then start the big strip down for restoration. :-)
              • K Simmonds
                • Dec 2007
                • 7627
                With an Audi S2/RS2 engine if it turned over smoothly and past a leak down test I'd have 99.9% confidence it would be fine, the six speed box's are also virtually impossible to break. Unlike newer cars.
                That said your way better off going for the Maxxecu as it is now impossible to get Motronc live mapped properly in the UK.
                1990 B3 2.0 80 quattro.
                1992 C4 2.8 Avant quattro
                1994 MTM RS2.
                1998 B5 TDI quattro Sport.
                2000 B5 TQS.
                • bazgreener
                  • Jan 2025
                  • 27
                  The car had lost its clutch after being standing but thankfully after bleeding it came back, what a fun job changing the clutch slave must be! Hard enough to bleed it
                    • Dec 2017
                    • 5983
                    Turn steering full left, remove gear linkage (one 10mm nut) and its quite easy. Work from top.
