Hi all,
still work in progress with the non start RS2.
I'm trying to communicate with the ECM on the bench but have no comms on the k-line pin, do i need to connect the L-line also? Using VCDS on the diag socket in the fuse box i can talk to some modules but not the ECM, i see a burst of data on the kline ECXM connection when i cycle the ignition switch but nothing else.
Can anyone help with how to confirm comms with the ECM?
thanks
thanks
