Sorry I forgot to put an "Other" category - can Mods help please?
@GT500 - can you elaborate on why they are "the best"...?
I'd also like to know why I haven't spotted your lovely RS2 around Leeds!
I don't know why you havent seen me around,,, usualy use it every day.engine having a quick rebuild at the moment so unless you pass my drive you won't see it!
HKS bov are a lovley piece of engineering. You can adjust the vacume release so it dosen't leak air on tick over. They have a huge intake hole, much bigger than most diverters so flows more air. Change the fin inside it and makes a tweety churp as it vents, just like waist gate chatter on hi boost cars, so no rs turbo chav crap noise!
Rob..
87 UR 20v ABY
97 S6 Avant
Rob, I take it your using the recirc flange with the HKS SQ ?
Perhaps I should add that I'm perfectly happy with the 710N, I'm just looking at "long life" alternatives, and it's just one less thing to eliminate when you have boost problems.
Past: S2 ABY coupe RS2 spec with lots of mods, S4 B5 saloon, RS6 C5 saloon, S8 D2 FL, RS4 B7 saloon, S4 B6 avant
