Any BTDT on how to change injectors?
  • Jonas_R
    • 3780
    • Country: Denmark
    Well,
    Iam going to change my injectors, so I was wondering if anybody got some BTDT or HowTo's?
    Is it a bad or easy job to do?
    /Jonas R.
    Sleeper S2 Avant +450
    A6 Avant 2.7t Stage 3
    Audi S2 Coupe RS2'ed
  • Rusty
    • 18953
    Removed mine on the ABY. Was an easy job requiring a 5mm allen socket, flat blade screw driver and a bit of care and attention.
    Please check that there aren't any additional fixings that I've forgotten as it was a few months ago when I did this:-
    Release the pressure from the fuel rail (can't remember if I did this or how to do it, sorry!)
    Remove 2 5mm allen bolts holding the rail to manifold.
    Remove 5 off clips at the top of the injectors being careful not to drop them into the engine bay!
    Remove 5 off plugs from injectors (press the wire clip towards the injector and pull).
    Carefully prise the fuel rail upwards, away from the head / manifold and perpendicular to the injector pointing angle if possible).
    Some of the injectors will stay in the head, others will come with the fuel rail.
    Carefully remove the injectors from the engine and rail as necessary taking care to take the O rings with them (one top, one bottom for each).
    Don't drop the injectors, the plastic bits on the end break !
    Refitting is the reverse or removal! (with a bit of rubber friendly lubricant (!) to help get the O rings in the holes!).
    • Jonas_R
      • 3780
      • Country: Denmark
      What happens if you dont realease the pressure?
      Car has not been started for a while now anyways.
      /Jonas R:
      • urquattro-island
        • Mar 2006
        • 1915
        • Home: Norway Current: Iceland
        well
        woooooshhhh is the right word
        japanischer industriabfall nein danke!!
        www.rackeltrim.se Icelandic Division
        • LHD_Kid
          • May 2006
          • 3695
          You'll be ok if it hasn't been started for a while...
          BTW, what would you use as friendly for the o-rings, are we talking vaseline or something?
          • Jonas_R
            • 3780
            • Country: Denmark
            Hehe oki kinda guessed that it would go woooosh
            But I mean is there going to be fuel all over the engine bay or what?
            Anysuggestions to how the pressure is realeased?
            /Jonas R.
            • martinjs
              • 3205
              BTDT a few times, On the 3b you need to undo the rear fuel hose on the rail (goes to the FPR) so you can remove the rail. Just undo it slowly and you should be ok, you will get a little fuel leak out obviously but its nothing major, just put some cloth around it to soak it up.
              • s2_bo
                • Oct 2005
                • 6067
                Dont forget to put out your Fag first too...
                You might lough but i know someone that did a fuel pressure test on a saab 900T with a lit fag in his mouth...
                Nutter...
                91 S2 coupé - RIP
                98 S8 - Luxury barge
                • Jonas_R
                  • 3780
                  • Country: Denmark
                  Yeah that would be really stupid
                  /Jonas R.
                  • volcano rs
                    • Jun 2005
                    • 2265
                    put some cloth over the pipe and release the pressure .and on o rings just lubricate them in a bit of engine oil
                    • s2driveruk
                      • 12696
                      can vouch for the 'if its been standing for a while'. small hiss, little mist of fuel over arms and cam cover, no drama.
                      1992 3b S2 Coupe
                        You can "release" the fuel pressure by starting the cold engine and then pulling the Fuel Pump fuse (not relay, the fuse). I don't know which on that is on an S2 but for a C4 S4 its No. 17.
                        The engine will continue to run until it runs out of fuel pressure in the fuel rail. Then it will stop. Turn off the ignition. Disconnect the battery (always safer) and start your injector removal.
                        • s2driveruk
                          • 12696
                          cool tip....should have done that before i started to dismantle the engine However after 4-5weeks on stands the pressure had subsided plenty
                          1992 3b S2 Coupe
                          • dubmeister
                            • 522
                            Another tip is to spray a little releasant(wd40/plus gas or similar) onto where the injectors mount to the inlet manifold, then twist the injectors out in a circular motion. This helps free the 'o' rings and stops them staying put( or falling into the port).
                            urs4boy has the best idea for the fuel pressure.
                            Its an easy job.
                            Good luck
                            • Jonas_R
                              • 3780
                              • Country: Denmark
                              Just want to say thanks for the good advise, everything went smooth
                              Jonas
