Ok, now you're talking, I'm pretty good with a multimeter! Any ideas what sort of voltage I should get? I'm guessing 12v?
Not running on all cylinders.....
Not sure but just test one that is known to be working and use that as a marker93 S2 Avant Parting
91 URQ RR
02 A4 tdi AvantComment
You could try an LED in the injector connector. It should flash with the injector pulse if you have a connection.SSComment
So...
...I'm back, and I'm still running on 4 cylinders
In addition to all the previous checks, I've now tried:
- Checking the voltage on injector No. 2. Its producing 14v just like the others. No problem there.
- Testing the cylinder pressures: 1=11.8 Bar, 2=12.1 Bar, 3=11.9 Bar, 4=11.2 Bar and 5=11.9 Bar. If anything the cylinder in question had a higher pressure than the others.
Any other suggestions, please
MarvComment
When did the fault first start was it anything that trigger it off?93 S2 Avant Parting
91 URQ RR
have you done everything stated here?
93 S2 Avant Parting
91 URQ RR
have you ran vag.com on the car to see if it has shown any codes?93 S2 Avant Parting
91 URQ RR
I parked the car up outside some shops for around 15 mins. Got back in started it up and found it running lumpy. It was running smoothly before. No warnings at all.When did the fault first start was it anything that trigger it off?
No, not yet. Do I just plug the spark plug into the coil pack and check for a spark when turning the engine over?Did you check for a spark on cylinder 2?
Yeah, I've read through it a few times and tried everything except replacing the fuel filter and checking if I'm getting a spark. Didn't think it would be the fuel filter because i've only got a problem on cylinder 2. Maybe I should change it anyway.have you done everything stated here?
http://www.sjmautotechnik.com/troubl...4_Ignition.htm
I don't have vag.com, is that something I can buy from VAG parts?have you ran vag.com on the car to see if it has shown any codes?MarvComment
93 S2 Avant Parting
91 URQ RR
Knightrider, you are a hero. More toys!!!!
MarvComment
dont forget to get the driver software for the lead(should be linked to the lead on ebay sale93 S2 Avant Parting
91 URQ RR
