Boost value on RS2 turbo?
  • Jonas_R
    • 3780
    • Country: Denmark
    Hi,
    What are the boost limits for an RS2 turbo, what boost values do people that run chipped RS2 have? Or what boost values do people have that have RS2'ed there coupe?
    Is it something like 1.7 bar peak at 5500 RPM and then dropping to 1.1 bar at redline?
    Iam going to use a RS2 turbo on my 3b instead of the hohenester hybrid, since I want more boost.
    /Jonas R.
    Sleeper S2 Avant +450
    A6 Avant 2.7t Stage 3
    Audi S2 Coupe RS2'ed
  • prosty
    • Jun 2005
    • 1114
    Don't go over 1.8 bar. the turbo won't last long then.
    2004 9-5 aero
    2009 Subaru Legacy Diesel
    1994 Toyota Supra Eurospec 6-spd LHD
    3-4 Audis in parts
    • Jonas_R
      • 3780
      • Country: Denmark
      Ok, so something like 1.6 bar peak and then dropping to 1.1 bar at redline. Does that seem ok on RS2 turbo or should i keep the boost even further down?
      /Jonas R.
      • prosty
        • Jun 2005
        • 1114
        1.6 is ok , good power and effiency .
        2004 9-5 aero
        3-4 Audis in parts
          My 93 S4 (AAN) is RS2'd with MRC software. My max boost is about 26.2 psi (TDS-1 equipped) or about 1.79 Bar. I have other (non-MRC) software that runs to 28 psi (+) or about 1.93 Bar. Forget the turbo issue, the pinging (pinking) is terrible. But it can make 317 hp at the wheels on a four wheel dyno (with 9L of toluene in with 71 L of 94 (RON+MON)/2.)
          YMMV
