Which Is The Best Way To Fit My Vdo Boost Gauge
  • 220bhp
    • 2578
    • Home: United Kingdom
    My VDO boost gauge arrived today,and I have done a search on fitting it ,but there seems to be a few differant ideas.I have the pod for the centre vent, and wondered if anyone can tell me what else I might need, or direct me to a how to.
    Many Thanks
    Lou
  • dest
    • 4287
    Im glad you posted this, as I will soon be in the very same position
    • HPmuirt
      S2Forum April Fool
      • Apr 2005
      • 3014
      I hope not, as I have not sent you a VDO gauge
      As for fitting, most people go the centre vent route, with the power taken from the aux gauges and the vacuum pipe connected to the ECU pipe (saves going through the bulkhead)
      There are loads of threads around on this and also lots people at the RR session will have this setup, so if you are going, you can have a snoop around.
      Cheers n
      Si
      Subtle mods here and there
      2011 A5 3.0 TDi - Lava Grey
        Really is easy all you need to do is pass the boost pipe from the centre vent round the back / side of the glove box and tee of the ecu pipe.
        I took power from the radio loom and used the illumination wire from the loom as well.
        If you can take an engine out this is a walk in the park
        • 220bhp
          • 2578
          Chears Jamo:thumbs and put it back it back in don't forget
          • dest
            • 4287
            Am I not allowed to buy a gauge from somewhere else and fit it there?
            • HPmuirt
              S2Forum April Fool
              • Apr 2005
              • 3014
              Absolutely not....I now own the rights to all boost gauges don't cha know, as I have supplied 28 to various forum members.....making me the Boost gauge king .....and don't you forget it
              Now, how many 'real' boost gauges can I put you down for?
              Cheers n
              Si
              • 220bhp
                • 2578
                All up and running, and boosting up fine I think. what boost should I see on a standard 3b.
                  0.8 bar on the 3B IIRC
                  • 220bhp
                    • 2578
                    Is that the maxi n all gears,and at what revs should it start to fall of. I am seeing 0.8 at times,but more often than not a little less
                      Just got mine fitted, works really nice, I'm missing my blue led though, the blue light won't shine through the red filters in the gauge I guess. I'll have to wire in the bulb (sorry, lamp?) that came with it. Which strangely has a green filter over it..
                        The pressure connector had me confused for a while, my previous gauge just had a push in connector with a ring to release it, once I worked out which way the olive went round I was ok though. I'm getting -0.5 on idle, back to the stop on overun, and just under 2Bar max at WOT.
                        • waveydavey
                          • Oct 2004
                          • 289
                          I'm going to be fitting my VDO boost gauge soon. What size of vac pipe and T piece do I need to be buying?
                          David
                          1994 16v Coupe - Sold on and sadly missed
                          1994 S2 Avant - Warmed up a bit
                          1995 A6 Avant - Dag Dag Delight
                          • dest
                            • 4287
                            Cheers n
                            Si
                            If there is another group buy, I will definitly be after one!
