Changed the after run pump on my 94 ABY avant last night. While I was waiting for the car to warm up after fitting the pump, I decided to have a listen around the engine bay. For quite some time I have had an annoying ticking coming from the engine and have always put it down to the injectors.
However, it would appear that this is not the case. I eventually tracked it down to the carbon canister valve. The ticking is so loud that I can hear it in the car while it is idling. Would someone tell me is this normal? Is it a fault with the valve and does it need to be replaced? Is there a method for checking it? And lastly, if it should be replaced, roughly how much is the part?
Thanks in advance
Alistair
Thanks in advance
Alistair
