034 motorsport GT3071R Stage I Kit
  • K7ERG
    • 1711
    interesting!!!!
    Audi A6 AEL 5cyl Quattro breaking.
    Audi A5 3.0tdi Quattro Stage 2
    07947385043
    Yeh love how it says the ABY needs a 4 bar FPR... err it has one standard!
    Personally I would touch it with it being supplied with a 1.9 bar wastegate spring.
    In other words this kit works of mechnical boost.
    • troman
      • May 2006
      • 42
      mechanical boost?
      yes...you still need to buy the GT3071 mechanism separately!
        Originally posted by troman
        mechanical boost?
        The ecu has no control over the boost pressure.
        Only boost pressure of 1.9 bar or above will open the wastegate.
        • sal_s2
          • 1287
          ADU has a 3.8bar fuel pressure reg
          • JSHADZI
            • Oct 2004
            • 66
            Hello all, just to clarify, the ECU certainly does control boost pressure, our 1.9BAR spring gives essentially 13psi of boost base (remember, that's 1.9 BAR Absolute, or .9 atmospheric), all the boost above this level is controlled by the Motronic ECU, which we've re-mapped to give the targeted boost levels safely and accurately.
            To my knowledge, the RS2 uses a 3.8 BAR regulator, thus the need to upgrade to the 4.0, if you have a 4.0 for whatever reason, then youre all set.
            Javad Shadzi
            www.034motorsport.com
            www.80tq.com
            • K7ERG
              • 1711
              Hi Javad
              Can you do away with the MAF?
              07947385043
                Is that 100% the spring rate is 1.9 bar absolute?
                That makes a hell of a difference if it is because the ones i've seen marketed aren't marked as absolute.
                • Corey
                  Banned
                  • Sep 2003
                  • 2793
                  sure, you just need one of these
                  Corey
                  01636 822288
                  • K7ERG
                    • 1711
                    Vems i think i am going with but if the Motronic can do without MAF then i might look into a chip set.
                    07947385043
                    • newt
                      • 40
                      I'm fairly certain the springs we make and provide with the kit are indeed 1.9 bar absolute....
                        I apologise if that is the case I would strongly recommend you highlight that on that page as like minded owners will see that and be put of!
                        • JSHADZI
                          • Oct 2004
                          • 66
                          1.9 BAR atmospheric is about 28psi, so the real question is, if in fact were supplying such a spring, how we're magically lowering boost from 28 to 23, now that's a skill!
                          Javad Shadzi
                          www.80tq.com
                            I've heard heard of more magically things like 350 bhp on a K24 with stock injectors .........
                            • Wheeljack
                              • May 2005
                              • 219
                              now we all know why psi is insufficient as a unit without reference, unless...how about psig and psia??? psi boost is usually interpreted as gage pressure, but when bar is referenced as a unit, boost may or may not be added to the unit, and this is where the confusion lies. what to assume if there is no modifier? well, i say absolute because my audi digital display shows my boost pressure this way, not gage pressure.
