low oil pressure :(
    ha ha, no i've spotted them during the course of my refurb excercise, just a case of whether i can get to them without removing the rad... i'll wait for my sensors then try replacing the lot i think
    Cheers for your help guys
    • Azman
      • Sep 2005
      • 3205
      you can if you don't like your knuckles very much!!!!! And the spanner you will need is a biggy by the way
      Dark Grey Avant
      RS2 FARB
      Alloy Subframe Bushes
        haha... for the oil pressure sender you mean?
        The others look to be fairly normal sizes from memory
        I've only got 3 knuckles left that i haven't skinned in the last week
        • Azman
          • Sep 2005
          • 3205
          Make that none by the time you have sorted these then. The front of the rad really does take the skin of doesn't it.....
          Dark Grey Avant
          RS2 FARB
            errr... yes!!! My rad still has bits of skin and blood still on it from swapping the alternator!!!
            So Az, does the cotton reel type pressure sender unscrew or does it pull out?
            Do you know if there are any copper banjos or o-rings that could do with replacing when i stick the lot back in?
            • Azman
              • Sep 2005
              • 3205
              nah the lot seal to the block. don't use any gasket stuff or alike. just do them up nice and tight. The cotton reel one I am gussing is the one just bellow the big prssure sender with only one wire on it... Big spanner.....
              No o rings as such, poss a copper crush washer, bout it really, just make sure they are done up properly or they will seep oil down the block..... Hint deal with the pressure sender first matey so you can get to the spanner bit under the tin can... You know what I mean
              Dark Grey Avant
              RS2 FARB
                thanks matey
                • AndyP
                  • 6049
                  Did you get anywhere with this issue?
                    Not really, now I have swapped in the low mileage 7A with a new different pressure sensor - I get over 2 bar at warm idle now so not worried about the bearings or pump - but still only over reads 4bar max, I think its the gauge itself tbh
                    I do have a 100psi pressure gauge I bought to test it properly, but never go around to making up a hose to connect it - was going to screw it in place of the white pressure switch and test cold start pressure, warm idle and warm 4k rpm...
