I`ve just bought a DTA S100 ecu and im starting on the engine loom.
I was just wondering if anyone had a diagram of the wiring for an ABY as im trying to work out the ignition system at the mo.
Im assuming on the two ignition modules (with three channels each) the 7th terminal on each of them is ground.
And on each coil with two wires, one is switched live and the other goes to the corresponding channel on the two modules leaving one channel spare (and i assume the coils must be earthed through the bolts that hold them onto the cam cover).
Thanks.
Thanks.
