Well the timing reference pin for G4 is at 62 degrees BTDC on #1 - this generates one reference pulse per crank revolution.
I *think* theres 135 teeth on the flywheel which triggers G28 for rpm. You might want to check up on that - dont have the facts in front of me.
G4 and G28 are inductive sensors - not hall effect devices. That 3rd pin you see on G4 and G28 is a screen/braid to reduce noise ingress. Pin 48 on the ECU is the nominal 0V reference point for them both.
Paul
Paul
