Just to clear something up - a generic chip upgrade is absolutely fine if the car is in full health. Now of course every engine is different - some rev harder than others, have better knock resilience, slight difference in fuel pressure, MAF output etc etc so there will be potential for slight difference in performance as a result of any upgrade.
Yes a truly custom remap could extract the absolutely maximum from any given car by customising to such small details but that is for the last few % of oomf on a standard setup. Alternately a custom tuner *could* work around a faulty FPR for example with different fuel maps, but thats a slippery slope.
Such a custom job is best suited to modifed configurations with funky cams, turbos, injectors and such where its all that more important to monitor EGTs, AFRs and such... On a stock setup - you know what to expect unless there is something badly wrong with air metering, fuel delivery or ignition... Assuming all things mechanical are OK and there are no boost leaks.
Paul
Paul
