I've broken my car!
  • jogi730
    • 2335
    Hey Andy,
    Sorry to hear you're having problems - disheartening I know!
    Just as a thought, are you sure the spares you have tried are all 100% - amybe the MAF you tried is also faulty?
    Maybe clutching at straws, but trying to help.
    CHeers
    CHris
    Audi 90 quattro (Typ 85)
    20v turbo conversion
    • catgroom
      • May 2007
      • 137
      Would,by any chance,the ECU retard the ignition timing/cut the fuel (when under load) due to knock sensor/s needing re-adjustment.Dont know why I say this if all was OK before,but just a thought.
      OK,I know sod all about S2,but this was the case on a car I once owned with a similar engine management set-up.
      Good Luck Andy
      Steve
      1994 2.6 V6 in LY6G Vanillegelb (Lime Pastel).
      202k,Throttle Body Ported,Stainless.
      • Rusty
        • 18953
        Couldn't get on it last night but going to give it a once-over tonight if I can. Dodgy connection somewhere is almost certainly what's up.
        Having pressure tested it I'd know if it was a split pipe or dodgy joint so I can rule that out.
        Going to check the continuity on the coil pack earth as the wiring here is a little tired and so might have split after being disturbed.
        Also going to check the ECU and fuse / relay boxes.
        The fact that it was running means that it's just going to be one thing (for now).
        I agree about it not being the TB.
        Have reset the ECU so will see what happens this evening.
        ...the fun continues...
        On a more entertaining note, my Milltek DP turned up yesterday! :mischeif:
        • GT500
          • Jun 2006
          • 2181
          I bet when you find the problem its nothing you touched whilst doing your head gasket.
          Coincidence! gets you checking all areas you have just worked on, usually something completely different!
          Bloody cars!
          Keep the faith!
          Rob..
          87 UR 20v ABY
          97 S6 Avant
          • s20ale
            • Aug 2004
            • 476
            Yes i agree these bloody cars . When there good there bloody GOOD .........but when there bad they are real BAAAAD
            Good luck Andy mate hope it's something really simple.
            • Rusty
              • 18953
              Nothing a gallon of petrol and amatch can't sort
              • pixsaudisex2
                • Sep 2004
                • 3110
                #22
                ok im not trying to annoy you but when you say it was ok for a bit was this after you took the wedge of the butterfly to allow more air to get in .. i was wonderiing if this wedge removed ment that all the cylinders dont get the air correctly to them causing a valve or something to burn out.. or on low throttle positons the air dosent get distributed evenly to each cylinder,, causing poor running,, i ask this because i was tempted to take the wedge of but thought it must do something to the air as it goes down the inlet like forcing it over the top to get an even sucking in, in each cylinder.. i hope you get this sorted its pants when they dont run right but gee it does make them seem fast once they work correctly...
                  #23
                  Andy - I think you could be on the right track with that idea as you would have had to remove and lift away the coil packs to get the head off... Could well be that some crusty old wiring in there has let you down - or you were really unlucky and snagged some of it when refitting the cam cover with coilpacks.
                  Keep us posted...
                  Paul
                  • DJones
                    • Jun 2005
                    • 2020
                    I had a similar problem almost exactly as you describe. It was on a Dialynx short quattro. Tried absolutely everything. Turned out it was sediment in the fuel tank due to the car standing for so long that blocked the fuel filter. Would start perfectly touch the accelerator... dead....
                    Just a thought..
                    • s2driveruk
                      • 12696
                      hmmm sorry to see you're having a nightmare on this. I'd also say MAF as i know when i didnt plug mine back in it would idle but when i tried to drive away it was terrible and killed the engine.
                      Good luck getting it sorted....you WILL break 300bhp
                      1992 3b S2 Coupe
                      • Jay
                        • Jul 2004
                        • 599
                        #26
                        Maf is def top of the list... try borrowing a know good one and don't rely on a 'spare', you need one off a running car! I have swopped what I thought was a 'good' spare in the past and got caught out
                        Do you run a aftermarket air filter and is it a oiled type?? They kill maf's
                        Check the pins in the maf connector are clean and in place as well.
                        Jay
