Check List:
Ignition. (From connectors to Plugs) Done.
Vacuum leaks. (2.1 to 2.2bar indicated but will check again)
MAF.
ECU. (Inc 3bar Map sensor and tubes, etc)
ECU Water Trap.
ECU Codes.
Throttle Position Switch.
Dump Valve. ((New AMD valve fitted) did not check the hose to the steel pipe though)
Waistgate. (Diaphragm + Setup)
Waistgate Frequency Valve.
Knock Sensors.
Fuel Pump.
Fuel Filter.
RPM and Timing Sensors.
Air Filter. (New K& N) Done.
Fuel Pressure Regulator.
Engine Tune.
Oxygen Sensor.
Have I missed anything?
Lastly, can you get a gasket that goes between the waist gate and the manifold? Although the joint is metal to metal, you can see a bit of exhaust gas escape (Black dust, etc) from the joint face. Torqued up OK. Might need longer studs though! (+5mm)
I have been onto “http://www.carbulbs-direct.com/u280-...anner-34-p.asp “They do a “U280, U281 and a U581” Will they all work? As I would tent to get a ‘U581’ or a U281’
MAF.
ECU Water Trap.
ECU Codes.
Knock Sensors.
Fuel Pump.
Fuel Filter.
Engine Tune.
Oxygen Sensor.
. That doesn't sound too good. Mechanical boost alterations (wastegat springs etc), are, IIRC, not the best thing for our cars. Unless different turbos, stronger internals etc are being used. IIRC it's an easy way of increasing boost but has many downsides.
