Oil leak from front of engine
    I've been away for a couple of weeks and left my car with Pete Berry to trace the oil leak I was getting at the Donny trackday, turns out when I removed the AC from the car one of the bolts from the brackets I took off should have gone back in, it was needed to stop the oil coming out.
    Embarrassing but may save someone else the trouble
  • s2driveruk
    • 12696
    ouch...which one?
    1992 3b S2 Coupe
      Newsh I think I know exactly which one, the AC bracket that plugs the oil return to the block?
      One of these?
      • dan_b
        • Sep 2003
        • 3670
        The sump plug?!
          Originally posted by dan_b
          The sump plug?!
          Arf arf, very drole Dan
          No Jamo it wasn't that one, I did take that bracket off and discover the big hole behind it (non AC car turbo oil drain). It was a long bolt, about 4" long, that goes through into a void where the oil pressure relief valve vents to? I guess it was holding the adjuster bracket or stay, as I've already sold the AC parts on that bolt must have gone with them. I haven't got a good picture in my mind of which bolt it was exactly.
          • dan_b
            • Sep 2003
            • 3670
            Sorry John
              yup. i had a similar issue with a bolt for the rear belt cover not being torqued up properly and coming loose, que oil dribbling down the front of the block and all over the pan etc back - felt really stupid when i found out what i'd done
              • Azman
                • 3205
                All good fun..... Remeber guys always fill the holes with what ever came out of it just in case......
                Dark Grey Avant
                RS2 FARB
                Alloy Subframe Bushes
                • Azman
                  • 3205
                  There is a double entendre there somewhere but I can't quite get my finger on it at this time of the morning!!!
                  Dark Grey Avant
                  RS2 FARB
                    So Newsh how long ago did you take out your Air con?
                      Just before the Donnington track day while I had it all in bits fitting the big IC and resprayed bonnet/bumper etc. Noticed the leak after the first track session, few drips of oil on the floor and a smell like the PCV wasn't working oil was getting blown back onto the hot exhaust.. Been trying not to drive it too much since then apart from sorting the misfire
