what a discovery !!!!!
Oooh. That was close.
UrS6 - Homefry, Bailey DV, PiperX filter, Samco hoses, H&R springs, 3" D/P back zorst, 270bhp and 260ftlb :rock:
Triumph Daytona 955i - mmmmmm :fire:
80 dag dag :driving:
Ok so the key is sheared - BUT if you had actually managed to bolt up the pulley to the correct torque with a new bolt etc - that damaged woodruff key would hold fine.
You don't honestly belive that all the engine's torque is transferred through a 5mm thick peice of sintered alloy do you?
I put my crank pulley back with a similar (though not as large) crack about 7k miles ago, safe in the knowledge that because the pulley was done up to the correct torque with a new bolt, then the key will hold fast - the compression of the pulley onto the crank gives such massive frictional properties - that key will not break.
Why do you think Yamaha/Duratec engines don't even have a key. (neither do zetec cam pulleys for that matter).
Sorry about the little rant - but I needed to set the record straight....
Now I'm off to hide..........
sigpicComment
too much of a gamble .i've been there with 10 bent valves and a snapped timing beltOk so the key is sheared - BUT if you had actually managed to bolt up the pulley to the correct torque with a new bolt etc - that damaged woodruff key would hold fine.
Every thing's tightened to the correct torque, I Know what I'm doing....Ok so the key is sheared - BUT if you had actually managed to bolt up the pulley to the correct torque with a new bolt etc - that damaged woodruff key would hold fine.
still didin't find how it happened
My theory is it happens when you tighten it, the nut moves the pulley round and breaks the key as you torque it up, this means if you use it again it might break completely while tightening and end up correctly torqued but in the wrong position.Comment
you mean you would change it every time you change your timing belt ?
The woodruff key breaks the crank still rotates but the cambelt does not as it is driven off the crank pulley which will be slipping, the valves therefore aren't closed in time and the pistons smash into them bending them.Ok so the key is sheared - BUT if you had actually managed to bolt up the pulley to the correct torque with a new bolt etc - that damaged woodruff key would hold fine.
Impossible scenario? Check the forum or ask Phil2.016v this is what happened to his Avant
The torque isn't the issue, the non rotation of the crank pulley in time is!Comment
Its little money for a lot of confidence...Paul Nugent
I Know about it, that's the reason why I posted this image.... so people can see what can happen even when work is well done !!!!!
I think I will now change it everytime !!!!
