Torque Settings
  • s2avant
    • 2426
    #31
    Not these days. They have globalised the pricing structure across the VAG group.
    Doesn't stop things like tappets being far too pricey though.
    Ben
    • APNess
      • 479
      Ah right. Well I was out of luck when I wanted a cam pulley wheel - Audi only part! (Unless someone tells me different, and it's used on VWs!)
      Current status of car - taking airbox out tommorrow and checking all pipes for leaks. Also gonna get a steel airbox made up at some point to house a big cone filter.
      I got a K&N racing filter from dialynx, but it clearly states - "for racing and off road use only - NOT for emission controlled vehicles". What difference will it make then to the emissions, anyone?
      Tom - have you got the same filter on yours?
      PJ
      'The Bacofoil Express'...
      No more.
      Leon TDI 150 run in now.
      Very slow.
      Needs a chip.
      • audiman
        • 4827
        I have the same filter etc. Makes no difference to the emissions.
        With regard to the tappets, i never put cams in without decompressing the tappets. That means taking them apart, doing it that way ensure that you never have any probs with valves hitting pistons. Trust me, i do this nearly every week.
        Not sure on part number, but the golf IV uses a cam pulley very similar on the 2.0 8V engine code APK. Will look into that.
        Tom C - www.rcmr.co.uk
        Audi UR Quattro
        Audi 100 C3 2.0 5 cyl 115ps
        Audi B5 RS4 645ps 911nm
          What is meant by "decompressing tappets"?
          • Jon441cc
            • Dec 2005
            • 2061
            Jamo ,The remaining oil is sqeezed out of them, I had the guys do this when i had the head rebuilt thumbs:
              How easy is it to do this as i may swap my exhaust cam over this weekend?
