2.3 20v Coupe wont start ! Advice needed !!
  • coco
    • Mar 2008
    • 66
    • Home: Orkney Islands Current: Scotland
    #76
    She runs !!!!!!!!!!!!!!!
    Moved the aux rad out the way and took the front cover off, lined up all the timing marks and checked the dizzy, noticed it was pointing slightly away from cylinder no1
    Took the dizzy out and turned it to allow for the meshing of the dizzy gear with the camshaft so as to have the timing marks on the hall sensor aligned and put it all back together and she fired up straight away !!!!!
    Only on 4 cylinders though as broke no1 HT lead off in the cap while trying to remove the lead !!!
    Am over the moon to hear her fire up really appreciate all the help from you guys on here, would have been a real struggle without all the help you have given me.
    Big thanks to spink as well for the bargain dizzy, cheers mate, i'll use you again if i need any other parts in the future.
    Getting new plugs and leads tomorrow and will also give her a good service seeing as its sat doing nothing for a year and a half. Cambelt dont look too bad to do so thats getting done as well.
    Thanks again everyone.
    • stiglet
      • Aug 2007
      • 1264
      well done
