Inlet manifolds flow test
  • terrybullwon
    • Mar 2006
    • 8782
    I saw this on Zatzy, I hope Martinssons does not mind them posted here to...
    RS2
    AAN
    034
    3B
    Chef
  • Acidburn
    • 13459
    Some interesting information there as I remember seeing this before.
    3b's good for something else again
    034 one I take it is a chopped or reverse one?
    • s2_bo
      • Oct 2005
      • 6067
      So 3b does flow more then RS2, there was some debate about this a while ago.
      Peter, the 034 one is reversed as the injector mounts are on the other side. Wonder how the manufacture is though? It doesn't look like a Wagner one unless its reversed.
      91 S2 coupé - RIP
      98 S8 - Luxury barge
      • Acidburn
        • 13459
        cheers for that, I was not sure.
        I'm trying to decide what to put on mine either the 3b or the porsche or even a reverse one?
        • HPmuirt
          S2Forum April Fool
          • Apr 2005
          • 3014
          I always assumed that the RS2 and ABY are identical internally (just badge differences on the outside) but has anyone ever demonstrated this?
          Cheers n
          S
          Subtle mods here and there
          2011 A5 3.0 TDi - Lava Grey
          • BRY
            • 3755
            Grant has an AAN inlet which has been port matched.
            His power levels are good enough for me.
            • Billman
              • 4129
              I think this test was performed by 034 Team and posted over a year ago in Motorgeek.
              Go Holset or Go RS4
              • Bram
                • Aug 2006
                • 2582
                That is correct. Javad did al the flow tests. The 034 IM is from Wagner AFAIK.
                The RS2 IM is different from the ABY and 3B as it has more capacity.
                • HPmuirt
                  S2Forum April Fool
                  • Apr 2005
                  • 3014
                  Really? Has anyone ever proven that?
                  If not, does anyone have an RS2 and S2 IM kicking around that they could fill with water to check the capacity?
                  If there IS a difference, does anyone have an RS2 IM for sale?
                  Cheers n
                  Si
                  • Acidburn
                    • 13459
                    I'd be interested to know this as like I said above i'm trying to decide what to fit to mine as the rs2 has to be modded to fit the 3b as newsh found out.
                    • Bram
                      • Aug 2006
                      • 2582
                      ..as on a Superflow bench with 28 inches. All within 4% max/min, within 1.1% of average or so, this is untouched right off the CNC. Just for reference 8) I'm getting a 3B flowed right now for comparison 8)
                      Javad confirms that the RS2 IM has about 1 liter more volume.
                      However the flowbench numbers show me I will never put a RS2 IM on my car!
                      • HPmuirt
                        S2Forum April Fool
                        • Apr 2005
                        • 3014
                        Does that mean you have an RS2 IM that you might not fit as it is no better than the 3B one? Wanna swap it for a VDO boost gauge? :mischeif:
                        Cheers n
                        Si
                        • Bram
                          • Aug 2006
                          • 2582
                          I think you can still reach high HP numbers with a RS2 or 3B IM (good for at least 516 WHP), but it's just the unbalanced flow over the 5 cylinders that I would like to prevent.
                          What I mean with this is that actually each cylinder has got to be tuned with a different AFR, while now you tune the whole engine on average AFR over the 5 cylinders, meaning some cylinders run a little richer or leaner. I guess you will get most performance an a equally flowed IM.
                          • Bram
                            • Aug 2006
                            • 2582
                            Here is Pisobiker confirming that the RS2 IM has a capacity of 4.2 liters (incl. runners).
                            The 3B IM has a volume of 3.3 liters.
                            • HPmuirt
                              S2Forum April Fool
                              • Apr 2005
                              • 3014
                              That is between a 3B and RS2. He makes no mention of the ABY. I always assumed that the ABY and RS2 were the same internally, anyone care to comment?
                              Cheers n
                              Si
