JE Pistons
    Originally posted by Floddy
    Ported head, other cams, reverse IM, tubular EM, bigger IC, GT35/40BB, forged steel rods, studs in head and bottom, etc. Will probably crank it up to what the turbo can deliver.
    Want something that works even with a bigger turbo and more boost, which I probably will get in the future...
    Pretty neat spec, if your going bigger in the future then 8:1 CR would be a good investment but bigger than a 35/40? I take it it won't be an everyday car
    • Floddy
      • Dec 2003
      • 222
      No, I've got another car as a daily driver, but I'm planning to drive to gatherings & meetings, track days etc, and some cruising.
      After the last rebuild (including the 35/40) I took some longer trips with it without any bigger problems besides that the idle went awol pretty often. And of course the time when I ended up tightening the oil cooler fittings, with probably tools made early in the 19th century, on an island in the middle of the Baltic Sea!
      But that was of course with not so aggressive cams and stock comp ratio.
      Red cars are the fastest ones...
      - Team Irry -
      • aelred
        • Jan 2005
        • 761
        Originally posted by Puglife
        If your going for 82.5mm JE's i can ask Aelred for a price for a set of 5 as i'm after a set fore 82.5mm bore as well and just comparing prices to see whats cheapest. I'm looking at 8.5:1 CR as well so if you want to pm me what your after i'll ask Aelred later today when i get a free minute.
        Jay
        With an order of 2 sets I can supply these at £530 .
        With an order of 3 sets I can supply these at £510.
        Sets have to be same spec.
        These applies to any size pistons from 81mm to 83mm with in between sizes.
        Aelred
        • Floddy
          • Dec 2003
          • 222
          Oh, that certainly sounds competitive!
          What piston specs are the price for? Options etc.
          - Team Irry -
          • aelred
            • Jan 2005
            • 761
            That is for whatever CR and size of bore. This is for the basic design with no extras.
            Rings are obviously included. Note that at that price it has to be for identical sets.
            Aelred
            • Floddy
              • Dec 2003
              • 222
              Ok!
              I don't know what options Jay had in mind? I was thinking of perhaps acc grooves, cr grooves, heavy duty wrist pins, dual pin oilers? But I haven't decided...
              Delivery times?
              And just in case I'm the only one who wants a certain spec - price for a single set, if possible?
              Thanks,
              Floddy
              - Team Irry -
              • aelred
                • Jan 2005
                • 761
                Personaly I would go for the racing piston with wasted skirt, ceramic coated deck, total seal rings, uprated pins. nearly 80gms lighter then basic piston. Good for over 800BHP.
                Approx. 200gbp more per set but will have to confirm price.
                Delivery approx. 4 weeks.
                Aelred
                • fritschki2
                  • Feb 2007
                  • 9
                  • Country: Luxembourg
                  #38
                  I'm also looking for some pistons/conrods and recently found this company on the net.
                  What do you think about it:
                  Get top-quality crankshafts, connecting rods, and forged pistons at PPM Racing. Our cutting-edge technology, including CNC machining and computer-aided solid modelling, ensures maximum strength and weight savings. Choose from 2618 or 4032 grade aluminium alloy, with hand de-burred pistons and precision-milled ring grooves for low-drag, lightweight performance. Experience the best in design and manufacturing with PPM Racing.
                  They use pistons from Wössner, a german company: http://www.woessner-kolben.de/
                  Fritschki
                  S2 Coupe 1995, VW T3 1987, Coupe 85q 1986 (over 4oooookm :rock: ), CQ swb - big HP - project in planning:shhh:
                  • aelred
                    • Jan 2005
                    • 761
                    Dont know anything about them but the price looks pretty good.
                    Aelred
                    • Puglife
                      • Jun 2006
                      • 731
                      Ok!
                      Thanks,
                      Floddy
                      I haven't finalised what i'm after yet and unfortunately engine parts have been put on hold for the next month or two... I'm going 82.5mm bore, 8.5:1 CR. total seal rings and larger gudgeon pins would be nice but we'll see what budget allows.
                      Jay
                      Jay - pug_life85@hotmail.com
                      1986 Audi UR quattro - WORK IN PROGRESS
                      1981 VW Mk1 Golf - "20v Jim, but not as we know it!"
                      • Floddy
                        • Dec 2003
                        • 222
                        Well, I'm in a bit of a hurry (or so I think), but I'll definately keep this option in mind. You never know what happens...
                        - Team Irry -
