Having messed about with some dump valves last week with Sal_S2, Volcano RS and S2 Nip
We ended up putting the dump valves in the reverse orientation of the stock dump valve as in the normal position the valves weren't holding pressure.
Check the thread below, it's so coincidental that over in the US they had the same problem with the same make valve!
Now this doesn't work for all dump valves, I've found over time that some DV's don't like being reversed and some do.
& 2 bar!
If you dont do that only spring force holds the valve shut.
