Noise over the rear right wheel when engine starts!
Hey folks,
When I start the engine from the S2, a noise appears over the rear right wheel, it is something eletric, but I don´t know what it is! It disappear some seconds later.
It is normal?
Any one knows what can be????
Reguards,
Rafael Pinto
Audi S2 1994/1995 Avant - Black
Audi RS2 1994/1995 - Black
Rafael, The only thing I can think of is the fuel pump which is in the tank on an S2. The only thing in the odywork which I am aware of is the air pump for the central locking. I have a Clifford alarm which locks the door on the car when the ignition is started,Is it something similar?
Does the car have an alarm? Are the doors locking?
I currently have a similar noise on the rear right wheel, in my case is like a buzz that only happens when I am driving very, very slowly in first gear or reverse. It was driving me nuts untill somebody pointed out if it always happened or only when fuel tank was low. Now I have seen it only happens when fuel tank is low, so it must be the fuel pump in my case.
Which brings me to the next question. Is the RS2 fuelpump a direct swap on the S2 coupe?
Does anybody have a spare RS2 fuelpump?
Or my problem is not the fuelpump? :wacked:
Ditto, mine is the same, i thought it was just the return line when the tank is empty-ish the returnline might suck in a bit of air when you switch the engine off, then once you start it, it is just spitting the air out again??
hope it is not the pump:confused:
Graham
Yep, got it too, but more like a soft buzz sound than gurgling and bubbling lol
anyway, fuel pump it is, I wouldn't know where else to look.
I've got the locking doors too at start up (setting on clifford alarm), and I've still got the (!) signal and beeps on start up, heck it's a carnaval mayhem when I start, signals on the dash, beeps, buzzez fron the rear, locking sounds all around me, god I luv this car
