Can I use wastegate from, say 200TQ or other model?
I was wondering if it is possible to use the wastegate from a 200TQ older models with the KW engine or is this a no go?`
I need to get my hands on a cheap wastegate and get it repaired since my own is a bit knackered. But I dont fancy taking my own off, since I need to drive the car around
Should be the same. The only difference is 10vt vs 20vt as far as fitting to the mani. Although a 10vt WG can be fitted to a 20vt. The only difference on 10vt WG's that I know of is on face of the valve itself. Later MC2/1B etc have a hex instead of a slot to hold it in place when removing the nut to remove the diaphragm.
